Old 24-Jan-2014, 5:35 PM   #3
Your Tv reception location has receivable Tv stations in all directions.
To receive the Tv stations.
Above the Peak of the Roof so that reception is not , obstructed , impeded , blocked , by the Roof and Building in All Directions.
Install a , www.channelmasterstore.com , CM5016 All Channel Antenna aimed at about 320 degree magnetic compass direction.
Here is how to a antennas , www.kyes.com/antenna/pointing/pointing.html
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com , or , www.amazon.com
Install a , RCA , TVPRAMP1R , preamplifier.
For 4 Tv's connected use a , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , www.hollandelectronics.com
The Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ DTV Channels ~ ATSC Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ Antenna Channels ~ DTV Channels ~ ATSC Channels ~ Air Channels~.
Channel scan for the ATSC Digital Broadcast Tv Channels.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception with a Tv Antenna in the directions of reception and so do buildings and other obstructions including your own roof and building.
Your location has reception in all directions.
Some and not all Nevative Affects are.
Absorbing and Blocking Reception.
The Best Practice is to install the CM5016 All channel antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions including your own roof and building.
