Old 24-Jan-2014, 11:48 AM   #8
No static at all
No static at all's Avatar
Did you try moving the antenna to different areas of the attic? The CS2V should work much better than it is once it is placed correctly.
I helped someone near you in Fairfax/Merrifield with the same antenna. It works well in his attic, but required experimentation with placement to achieve satisfactory results.
