Old 24-Jan-2014, 8:08 AM   #10
MattZuke
You can certainly try the less expensive route suggested by teleview... if replacement of a balun (matching transformer) and/or a section of coax provides reliable reception, I'd hate to have talked you into spending hard earned $s that did not need to be.
No worries, presuming a Radio Shack balun (15-1230) is adequate I'll do that first. Given I saw no improvement using freshly cut cable from Click I'm thinking it's not a cable problem.
I can "just" swing a DB8e with a tripod if the $6.00 solution doesn't pan out. Additional Yagi will have to wait.
Thanks much.
MattZuke is offline   Reply With Quote
