Old 24-Jan-2014, 6:47 AM   #7
Originally Posted by Jake V View Post
Thank you for your responses.
I understand that there is signal loss when the antenna is hidden in the attic. Yet, it makes sense to try it since the coax was already in place.
Trying the antenna on the roof will have to wait until the snow melts and I can borrow a ladder.
In the meantime, if I decide to try another antenna in the attic what would you recommend?
Your TVFR indicates that the CS2V should be doing very well. That it's not, is almost certainly an indication of the poor reception conditions in your attic. A larger antenna may or may not help... consider the Antennacraft HBU-44 or HBU-55.
