I am not their to see the antenna , if it is broken or not , that is why I am asking.
Replacing the matching transformer and coax and running the coax directly to 1 Tv is a way to Test reception by eliminating problems.
The idea is to keep it simple.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception with a Tv Antenna in the directions of reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Tv Reception.
As you can see , looking at the Digital Current Plus Pending Applications Included Radar Map the Main Groups Tv Stations are to the , North West , North , North East.
