Old 23-Jan-2014, 6:11 PM   #2
I'd go at this in stages. Install the larger antenna first. You may get lucky and get 19 & 43 without the need for a second antenna.
I'd pick the 7698...
If a second antenna is needed, I'd mount it outside where it has higher quality signal to intercept and lower levels of in-home interference to contend with. An Antennas Direct DB2e would be my choice if only chasing real CH-19 & CH-43.
