If I was starting from scratch, with no hardware yet purchased, I'd use a system such as suggested by ADTech. (If I had no ANT-751 on hand, I'd use an Antennacraft Y5713 to 'get' the lone VHF (real CH-12).
That said, conditions improve significantly when you raise the antenna height... Enough to expect the ANT-751 to do very well if mounted higher than it currently is.
