Old 23-Jan-2014, 3:47 PM   #4
The signal strengths in improve at 25 feet antenna height above ground and a little over half of the reception of Tv stations are in the Green reception zone and LOS Line Of Sight reception.
Because you have the ANT751 antenna , work with the ANT751.
Installing the antenna higher will be a big help for reception.
www.ronard.com/909911.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com
Home Depot and Lowes have , Top Rail , chain link fence Pipe , 10 feet long , that makes a good antenna mast to get the ANT751 higher above ground.
To prevent the coax from swinging in the wind on it's way up to the antenna , feed the coax up through the inside of the pipe and out the top of the pipe.
Install a , RCA , TVPRAMP1R , preamplifier.
Connect All parts , (the power supply , the power injector , the preamp) , of the preamp before any splitters.
