Old 23-Jan-2014, 1:43 PM   #4
I'd suggest a reflector-less DB8e mounted in a location that allows you reception of both the Greensboro and Charlotte stations provided there is decent line of sight in all those varied directions. WTVI, the lone VHF channel in the whole area, will likely require special attention.
The antenna would be installed so that the panels, as viewed from overhead, are facing northeast and southwest.
Removal of the reflector panels requires drilling out rivets, so take appropriate safety measures.
