Old 23-Jan-2014, 4:59 AM   #41
Damon459
Ok not sure anyone is following this thread anymore but I have now tried the Wingard PR8800 8 bay antenna and the Antennas Direct 91XG to try and receive KTMF. I was not able to pick up any signal from that station at all. If anyone was reading from the beginning they would see I did have limited success with the Clearstream 2V with KTMF, the signal strength according to my Sharp Aquos tv was 50-55%. So I called Antennas Direct and they believe the reason it worked with the C2V was do to it having a wide beam width, so my question is are there any other options based on this idea? I don't know of any other UHF Antenna with a beam width wider then 70 degrees, and can be mounted on my roof.
Damon459 is offline   Reply With Quote
