Old 23-Jan-2014, 3:34 AM   #2
Aim the VHF/UHF antenna at about 358 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Install a New matching transformer (balun) to the antenna.
Connect a New Continues length of RG-6 coax to the new transformer and run the New Continues length of coax through a open door or window direct to 1 Tv.
The Digital Tv Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ ATSC Channels ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Digital Tv Setup Menu and select ~ ATSC Channels ~ DTV Channels ~ Antenna Channels ~ Air Channels ~.
Channel scan for , ATSC-Digital Broadcast Tv Stations:Channels.
Last edited by teleview; 23-Jan-2014 at 8:25 PM. Reason: Clarify information and typos.
