Old 23-Jan-2014, 3:06 AM   #6
Reliable reception of the Philly Tv stations is not about trying different types and kinds of small antennas.
The Current Tv Channels that are being transmitted and received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your location has receivable channels in All 3 Tv channel bands.
The Tvfool , Digital Current Plus Pending Applications Included Channel List.
The , Real channels colnum shows , KJWP on Real channel 2 and WPVI on Real channel 6.
Install a Big All Channel Antenna.
The Philly Tv stations are , At Distance , Are Weak Signal Strength , And have 1 and 2 Edge Path Obstructions = hills and mountains.
For reception of the Philly Tv stations install above the Peak of the Roof a , www.antennacraft.net , HD1800 All channel antenna aimed at about 115 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Install the RCA preamp.
Buy the , HFS-2D and HFS-3D , splitters at , www.hollandelectronics.com
No antenna rotation with antenna rotator is required.
Directional antennas such as and not limited to the HD1800 antenna receive the best at the front of the antenna , a little less at front angles to the antenna , less at back angles to the antenna , less at the back of the antenna.
And receive the least amount of signal directly on the sides of the antenna.
With the HD1800 antenna aimed at about 115 degree magnetic compass , that will put your local Tv stations at angles to the antenna , the local Tv stations signals are strong at your reception location.
So most of the locals will be received.
The Only Way to Know how many locals are received is to install the HD1800 antenna and find out.
The HD1800 antenna Must Be Installed Above The Peak Of The Roof In Such A Manner That Reception Is Not , Obstructed , Impeded , Blocked , By The Roof And Building In All Directions.
Here are some Strong and Sturdy Above the Roof antenna mounts.
www.ronard.com/909011.html
www.ronard.com/Tripods%200703/4712.html
Use the , ronard(4712-50-10) .
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com
Or , www.amazon.com
Last edited by teleview; 23-Jan-2014 at 5:18 PM. Reason: Clarify information and typos.
