The standard Tv antenna rotator that turns a standard Tv Antenna Is Not channel surfing friendly.
Must wait for antenna to rotate and if more then 1 Tv is connected there will be domestic situations about the direction the antenna is rotated to.
As I have recommended , aim the HBU44 antenna in one direction and you will be Suprized at the number of Tv stations received on the other directions.
