Old 22-Jan-2014, 10:48 PM   #9
Above the Peak of the Roof install a , www.channelmasterstore.com , CM5016 antenna aimed at about 140 degrees magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
A antenna system amplifier Is Not Required.
For 3 Tv's connected use a simple common 3 way splitter.
For 4 Tv's connected use a simple common 4 way splitter.
www.ronard.com/909911.html
Use the , ronard (911) , 5 foot tripod antenna mount.
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com
, or , www.amazon.com
www.ronard.com
www.amazon.com
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Absorbing and Blocking Reception.
Multi-Path Reflecting Bouncing Tv Signals Bouncing All Around.
The Best Pratice is to install the CM5016 antenna at a location the has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building.
The Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv tramissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tvs will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Memu and select ~ ATSC Channels ~ DTV Channels ~ Antenna Channels ~ Air Channels ~.
Scan for the , ATSC-Digital Broadcast Tv Stations/Channels.
Digital tuners can develop -Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
www.wchstv.com/DoubleReScanAlert.pdf
Last edited by teleview; 24-Jan-2014 at 4:16 AM. Reason: Clarify information and typos.
