Old 22-Jan-2014, 9:38 PM   #10
Your report indicates that you have a significant bit of terrain between your location and the local towers. Click on the call sign of a given station to see the path profile...
I'd try moving the existing antenna outside the attic, so you have access to high quality signal.
This test is helpful even when we already know an amplifier should not be needed. It can help you assess the need for a change of antenna or it's location.
