For a decent guess of how to adjust the aim, I figured I needed the location of the side lobe of the beam pattern (degrees off main lobe).
It doesn't matter since Winegard uses a scaling factor on their polar plots that exaggerates the main lobe but gives little detail about any side lobes.
The 7696P data sheet is at http://www.winegard.com/kbase/upload/HD7696P.pdf
