Old 22-Jan-2014, 8:26 PM   #8
Jeepaholic
I'm considering the suggestions for both omni, and uni-directional units here, thanks. While I'm picking your collective brain, what are you thoughts on the Winegard MS-2002? 6 or so years ago when trying to decide what I wanted to go with (antenna-wise) Winegard kept coming up. Seems it's a well respected company. So, what do the educated masses think?
One issue here is the WAF (wife approval factor) and the fact that I have young kids using the tv. Any decision I make will get veto'd if there is switching that needs to be done to watch certain channels.
A little more about my setup.
Antenna is mounted about 4' above the top of my chimney (single story house). I well replace the coax cable with one continuous run when I replace the antenna. I will also raise the antenna about 6' or so.
The coax runs into eyeTV tuner card that goes into a mac mini with PVR software installed.
Jeepaholic is offline   Reply With Quote
