Old 22-Jan-2014, 7:27 PM   #6
If you will like to receive the Detroit Tv Stations and -->Many<-- of the Digital Broadcast Tv stations in other directions.
With out a antenna rotator.
Install Above the Peak of the Roof install a , www.antennacraft.net , HBU 44 antenna aimed at about 140 degree magnetic compass direction.
Here is how to aim antennas, www.kyes.com/antenna/pointing/pointing.html
Use a Real and Actual magnetic compas to aim antenna.
Directional antennas such as and not limited to the HBU 44 antenna receive the best at the front of the antenna , a little less at front angles to the antenna , less at back angles to the antenna , less at the back of the antenna.
Directional antennas such as and not limited to the HBU 44 antenna receive the least amount of reception directly on the sides of the antenna.
The action to take when making antenna aim adjustments is to have the Tv stations of other directions at angles to the antenna.
Recommend Test reception without a antenna system amplifier and have only one Tv connected for the Test.
Running a New Continues length of coax from the antenna through a open door or window direct to 1 Tv.
Here are some Above the Roof antenna mounts.
www.ronard.com/909911.html
www.ronard.com/34424560.html
Use the , ronard (4560) , eave antenna mount.
www.ronard.com/ychim.html
Measure around the chimney and use a , ronard (2212) , ronard(2218) , ronard (2224) .
Buy the ronard antenna mounts at , www.ronard.com
I think you will be Suprized at the number of Tv stations and channels the are received and the reliable reception.
Digital Broadcast Tv Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
www.wchstv.com/DoubleReScanAlert.pdf.
Last edited by teleview; 23-Jan-2014 at 12:57 AM. Reason: Clarify information and typos.
