Old 22-Jan-2014, 7:05 PM   #6
Re. How do I do that?
Please read: http://forum.tvfool.com/showthread.php?t=4
When generating a TV Fool report, my preferred method is to open the Interactive TV Maps tool. Leave the 'input method' set to the default, 'address'. Then, enter only the Postal Code, and then click the 'Map This' button.
At this point you should have a map displayed, with a movable cursor located at the center of the Postal Code that was entered. Use your mouse to drag the cursor to the exact location you're interested in. In the upper right corner of the map you can select view types, I find it helpful to use both.
At the bottom of the map, enter the antenna height. Please use the highest value that you can safely consider installing. If you aren't sure, then use 25'. FWIW, You can also find the LAT/LON coordinates of the cursor (in decimal form, not deg/min/sec).
Once the cursor location and the antenna height are set correctly, click on the 'Make Radar Plot' button located at the upper right corner of the map. The TV Fool report opens in a new tab or window. You can then copy the URL from the address bar of your browser, for posting to a thread.
I hope this helps, I just want to be sure we give you advise based on the actual conditions at your location.
