Old 22-Jan-2014, 6:10 PM   #2
You don't have a signal strength problem, you have a signal quality problem.
Most likely, you've either got the antenna is what is a dead spot for that channel (move it), FM interference (install an FM filter), or electrical/electronic noise interference (much tougher).
Check your TV set's menus (and owner's manual). Look for anything related to diagnostics or antenna adjustments. Many sets do not include such a tool, so don't be surprised if yours doesn't.
