I think that Dave is probably right about channel 26: I have a feeling that you are just in an antenna null where you have the DB-4 aimed.
As far as PBS goes, can you pick up WCBB from Augusta decently?
WMEA is so close that I have to think that yours is a multipath issue and not a signal strength issue for you. If you decide to use a preamp, be sure to use a high-input preamp like a Winegard HDP-269, as you have enough signal arriving at the antenna to create an overload situation with many preamplifiers
