			The setup referred to has worked pretty well.  However, there are a couple of main stations (KSAT & KENS) that are somewhat weak.  I'm thinking a rotator might be a better solution since almost all I watch is from the cluster of towers to the south and I only occasionally watch the others to the west and north.  Plus I could put the reflector back on the CS2, which should increase its reception.  Any thoughts?
