I agree with the others here about getting the antenna outside. This should solidify the DC stations. I would try connecting just 1 TV & test reception before adding the amplifier. The nearby tower @ 495 & 29 has 1 strong TV & 2 strong FM signals which will prohibit use of certain amplifiers.
The Baltimore & Annapolis stations will still likley not be seen with the CS2V mounted outside. Your elevation seems to be slightly below the average local terrain which is likely creating poor signal quality. The weaker stations will require a larger antenna to compensate for those conditions.
