Have you tried replacing the coax cable? Deteriorating reception, over some period of time suggests water is entering the coax. If so, the only solution is to replace the cable. Even if you could thoroughly dry wet cable, its' operating characteristics will have been permanently altered.
If the antenna is functional, why replace it?
