Old 22-Jan-2014, 2:56 AM   #9
Mrbowtie26
Originally Posted by teleview View Post
--->As Always<--->Antennas receive the Best with least amount to No Amount obstructions in the directions of reception.
Aim 1 panel of the DB8e antenna at about 26 degree magnetic compass direction.
Aim the other panel of the DB8e antenna at about 189 degree magnetic compass direction.
The PA-18 preamplifier is most likely overloading from the Strong Tv signals.
This overloading from the strong signals will make reception worse on some channels.
Remove All parts of the preamplifier , Remove the preamp unit , Remove the power injector , Remove the power supply, and Remove any other amplifiers.
For this Testing of reception have only 1 Tv connected.
No splitters.
Sounds like a good idea I was considering that the pre amp could be causing issues. I will try this within a few days whenever it stops snowing :-)
Thanks for the info
Ron H.
Mrbowtie26 is offline   Reply With Quote
