Old 22-Jan-2014, 1:52 AM   #4
Nakattk
So from what I read above I do not have to ground the antenna mast. See if this sounds right? My coax comes from the street to a splitter outside that has a copper wire tied to my ground spike coming off it. The my tv cable splits and goes into the attic where it meets another splitter. If I disconnect the cable from the attic splitter that means the attic splitter is no longer grounded. So now my coax has no ground. I wanted to put antenna in attic then run coax to that attic splitter. Would that be ok now that it is not grounded?
Nakattk is offline   Reply With Quote
