Old 21-Jan-2014, 10:24 PM   #12
Replace the outside coax with , New RG-6 coax.
Use the coax that has the Compression type connectors on the ends of the coax , not the crimp type connectors on the ends of the coax.
And is a good idea to replace other outside connections such as coax ground block and splitters and etc. .
When all is setup and working correctly.
To make Double Sure weather water does not get into outside coax and etc. .
Wrap with , www.coaxseal.com
