Old 21-Jan-2014, 10:05 PM   #2
How , housing covenuts, and etc. are Null and Void by the Federal Antenna Law that Clearly States that a Broadcast Tv Antenna of Any Size can be installed above the roof in such a manner so as to have reliable Tv reception.
Hoa's and housing covenuts and other over bearing people and oginazations are aware of the Federal Antenna Law and the Fact that the Federal Antenna Law protects you and missions of other people.
Some Hoa's and people and orginizations will keep their mouth shut about the Federal Antenna Law , thinking you and millions of other people will not find out about the Federal Antenna Law.
And if you do know about it you will not understand that you can install a Broadcast Tv Antenna of any size above the roof so as to have reliable reception.
Some Hoa's and etc. will try and trick you by saying you can not install a Broadcast Tv Antenna that is larger then 1 meter.
The 1 meter size applies Directly to the small staeite dish and not the Broadcast Tv Antennas.
The Federal Anyenna Law is written in a way that Stops Hoa's and etc. from being over bearing and taking away your rights.
www.fcc.gov/mb/facts/otard.html
Attics and inside of buildings Are Not a reception friendly environment and Never Will Be a reception friendly environment.
The signal strength Tv reception is strong signal strengths at your reception location.
Yes you can start with a , www.antennacraft.net , HBU11K , antenna in the attic aimed at about 220 degree magnetic compass direction.
Here is how to aim antennas, www.kyes.com/antenna/pointing/pointing.html
A antenna system amplifier is not required.
www.amazon.com
If reception situations/problems happen in with the HBU11K antenna in the attic that are not resolvable by adjusting the antenna aim direction and changing the location of the HBU11K antenna in the attic.
Then move the HBU11K antenna to Above The Peak Of The Roof and aim the HBU11K antenna at about 220 degree magnetic compass direction.
As Allways , trees and tree leaves , plants and plant leaves , have Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Absorbing and Blocking Reception.
The Best Pratctice is to install the HBU11K antenna or any other antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building.
The Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv Tuners will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Digital Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ .
Scan for , ATSC-Digital Broadcast Tv Stations/Channels.
