Old 21-Jan-2014, 6:49 PM   #2
The Digital Broadcast Tv Stations/Channels to the , North West are Strong Signal Strength and will be received through the back of a , www.antennacraft.net , HBU 44 antenna.
The Digital Broadcast Tv Station/Channels to the , South East-East are Weak Signal Strength.
Aim the HBU-44 antenna at about 110 degree magnetic compass direction.
Install a , RCA , TVPRAMP1R , preamplifier.
For , 2 , 3 , 4 , Tv's connected use a.
HFS-2D or HFS-3D or HFS-4D.
Buy the HFS splitters at , www.hollandelectronics.com
Install the , HBU-44 antenna Above The Peak Of The Roof.
www.ronard.com/909911.html
www.ronard.com/34524560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com.
www.amazon.com
www.ronard.com
As always , trees and tree leaves , plants and plant leaves , have Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Tv Reception.
The Best Pratice is to install the HBU-44 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv's Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tuners will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ .
Scan for , ATSC-Digital Broadcast Tv Stations Channels.
Last edited by teleview; 22-Jan-2014 at 6:17 AM. Reason: Clarify information and typos.
