Old 21-Jan-2014, 4:45 AM   #2
I suspect the problem is that WCBS (azimuth 250°) and WFSB (azimuth 26°) are operating on the same frequency, real CH-33. If you are handy with metal fabrication and feel up to a challenge, consider stagger stacking a pair of identical UHF antennas.
http://forum.tvfool.com/showthread.php?t=1024
http://www.anarc.org/wtfda/stagger.pdf
The idea is to minimize the amount of interfering signal received from the rear of an antenna so that the desired signal can be received.
I would consider using a pair of 91XG antennas if I decided to attempt this project.
