Old 21-Jan-2014, 4:16 AM   #2
The local Sacramento stations should be easy to receive. I'd use an all channel antenna such as the Antennacraft HD850 or Channel Master CM-3018. This gives you a good shot at seeing KCSO-LD which is reported to carry ME-TV in addition to Telemundo. http://en.wikipedia.org/wiki/KCSO-LD
You could build a second, separate system aimed at San Fransisco using a lager, more aggressive antenna or combination of antennas... happy to elaborate if you're interested.
