Old 21-Jan-2014, 3:01 AM   #1
Mrbowtie26
Opinions on Antenna/Setup for my goals
Hello,
Here is my current location/signal:
http://www.tvfool.com/?option=com_wr...5b943d3758f393
I have decided to cut the cord and only get internet along with Netflix and Amazon Prime for entertainment. I am trying to get reception from the empire state building which is @236 degrees. I have a DB8e antenna that I have tried along with an Antennas Direct PA18 Antenna Kit (18.6 VHF db, and 15.4db UHF gain.) Mounting it on a pole approx. 25 feet high. I get about 14 channels. What I am trying to do is get WCBS-DT. I can't even pick it up at all. Strange thing is that I can get WXTV-DT which I believe is broadcast from the same tower. I have considered an antenna such as the Antennas Direct 91XG but I am not sure if it would be better for this or not. I have decided that before I order more antenna's that I would use a larger pre-amp so I ordered the AntennaCraft 30dB High Gain TV/FM Mast-Mounted Amplifier 10G212 thinking maybe it would help getting WCBS-DT. Please note I have no issues with purchasing another antenna and using it along with the DB8e. If I could get the signals coming out of Hartford around 13 degrees also that would be a huge plus. The reason I need WSBS-DT is unfortunately I am a New York Jets fan and they normally are broadcast on CBS out of New York but the CBS out of Hartford just broadcasts the Patriots games. Any help would be greatly appreciated.
Thanks
Ron H.
Mrbowtie26 is offline   Reply With Quote
