Old 21-Jan-2014, 1:29 AM   #4
StephanieS
Wink
Hi Dave,
Thanks for the additional info. You are right, trees and very localized obstructions TV fool won't account for. This creates a much more hostile situation. You may find with the most aggressive set up, you still don't have satisfactory reception. All you can do is pick the best spot on your property for signal and then try.
In your earlier post I misread one detail. K41DT which provides NBC and CW programming is at heading 278 with the PBS and ABC while CBS and FOX are at 59 degrees magnetic. Magnetic 278 requires high-VHF (real channels 7-13) and UHF (Channels 14 and above) while magnetic 59 requires UHF only.
With this new info, I suggest a 2 antenna system for magnetic 278 with an option for a third dedicated antenna for magnetic 59. We'll start with the two antenna setup though.
For magnetic 278, I would install an Antennas Direct DB8e http://www.solidsignal.com/pview.asp...nna-%28db8e%29. This antenna may be favorable due to it's ability for each half of the antenna to be adjusted separately. This is advantageous in multi-path situations or if you are getting reflections from terrain. The "bounce" may be a better signal to receive from than the TVfool heading! This antenna gives you that flexibility should you have signal reflection to contend with.
This antenna also allows for one half of the antenna to be pointed off axis from the other. I would start by testing and orientating one half of the antenna to magnetic 278, then the other half to magnetic 59 to see if that yields all the UHF signals you are seeking.
Further, I would add an Antennacraft Y5-7-13 for high-vhf coverage for your PBS affiliate. http://www.solidsignal.com/pview.asp...u=716079000987
Orientate Y5-7-13 to heading 278.
To summarize with antenna headings, you have the DB8e with one half orientated to 278. The second half of the DB8e should be orientated to 59. The Y5-7-13 should be orientated to 278.
Install on tripod located on the roof with 10' pole. http://www.solidsignal.com/search/sr.asp?q=tripodPut DB8e at the top of the pole. Install Y5-7-13 four feet below on the same mast. Suggestion: before drilling, stand antenna on roof in a couple of varying locations to test reception
On pole below Y5-7-13 mount an Antennas Direct EU385CF-1 coupler. http://www.solidsignal.com/pview.asp...u=853748001705 This makes two antennas (high-vhf and UHF) combined into one coax. Input DB8e coax into UHF input, into VHF input run jumper from Y5-7-13. Run single coax into your home.
As prior, after aiming is finished hook up coax into one TV with nothing inline then perform channel scan. You'll know quickly if you have reception.
This is my introductory set up with your added info. Knowing you have trees and geography, we'll see if it is enough. If your tests don't prove reliable reception, then then invoking a 3rd antenna while you have the DB8e fully concentrated on heading 278 might be something to discuss.
For starters though, this is serious setup that gives you several extra notches on the HBU33.
Let us know how it goes!
