Old 21-Jan-2014, 12:42 AM   #3
The Tv Must Channel Scan for the , ATSC-Digital Broadcast Tv Stations Channels , often named the ~DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv setup menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ .
Channel Scan for , ATSC-Digital Broadcst Tv Stations/Channels.
Also Digital Tuners can develop -Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Resacn.
www.wchstv.com/DoubleReScanAlert.pdf
Put a , TERK HDTVi ( not HDTVa ) antenna in a , window or patio/balcony window or patio/balcony door window , that as a first choice faces , North East.
If not North East , then North or East.
Aim the HDTVi antenna at about 46 degree magnetic compass direction.
Here is how to aim indoor and outdoor Tv antennas.
www.kyes.com/antenna/pointing/pointing.html
Extend the dipole reception rods out and put the dipole reception rods in a Low vee position.
Window glass passes Tv signals easier then walls.
If the coax from the antenna runs through the apartment to get from the antenna to the Tv , then that is the way it is.
Why??
Reason , Reliable Reception Is More Important Then objections to coax running through the apartment.
