Old 21-Jan-2014, 12:24 AM   #11
RedAliCat
Originally Posted by teleview View Post
+=>This is why I recommend the larger CM4228HD antenna to receive more signal for reliable reception.
Thank you. Would you also suggest aiming it at 36° on the compass as an earlier post suggested on another antenna? Also, should this antenna be tilted back, too?
Use New RG-6 Coax , Outside.
To help keep weather water out of outside connections.
Use New RG-6 Coax that has the Compression type connectors on the ends of the coax , not the older crimp type connectors on the ends of the coax.
Thank you. I wouldn't be surprised if there's water in the current coax. It would explain the freezing conundrum.
RedAliCat is offline   Reply With Quote
