Old 20-Jan-2014, 8:14 PM   #1
hblock
Trying to get set-up by Superbowl time
Here's my situation:
Pulled the plug on DirectTV about 4 months ago and switched to online streaming of Hulu and Netflix. Did this on a trial basis just to make sure we could live without it. So far, so good, so now I'd like to add an HDTV antenna to receive OTA broadcasts. Here's my map.
http://www.tvfool.com/?option=com_wr...5b94ec25fdbdbc
My plan is to remove the DirectTV dish and install the antenna on the mast left behind, which is at the lower edge of my roof two stories up (~25ft up). Ideally, I'd like to get the major networks (ABC, NBC, CBS, FOX). PBS and CW should be available and would also be nice to have. Looking at the radar map, if I could just get all the LOS stations listed, sans the 215 deg one, I'd have everything I'd want. This means I need to get the 6 stations available at 62-63 deg and the 2 stations at 359 deg. I really want to avoid a rotor if at all possible and was looking at a Winegard MS-2002 as a possible solution, but just not sure it'll cut it. So I'm looking for some advice on what hardware would work for me. Thanks for any suggestions.
hblock is offline   Reply With Quote
