Old 20-Jan-2014, 7:43 PM   #3
DrDave
Thanks Stephanie for the reply. As far as my goals, the main networks you mentioned are what I'm looking for. The must-haves are WVIR (either thru W41DT or W30CT), WVPT, WSVF, WHSV, which are all Charlottesville or Harrisonburg stations. Roanoke, Richmond or Lexington are not required.
One thing to note that I'm not sure that the plot takes into account is that I'm in between two ridges, one to my east and one to my west, both of which have 2 story houses on top of. There are also a fair number of tall trees on the ridge to the east. That may make the signals from Massanutten (50 deg) and Elliots Knob (269 deg) more challenging so perhaps a beefier antenna may be in order?
The antenna will be run to one HDHR tuner, with a run length of approx. 50'.
With this additional info, would you stick to the HBU33?
DrDave is offline   Reply With Quote
