Old 20-Jan-2014, 9:08 AM   #4
Many of the receivable Digital Broadcast Tv are weak signal strength at your reception location.
For maximum reception and flexibility of use.
Install a , Antennas Direct , DB8e , UHF antenna aimed at about 156 degree magnetic compass direction.
And install a , www.antennacraft.net , Y10-7-13 , VHF high band antenna aimed at about 156 degree magnetic compass direction.
Install a RCA , TVPRAMP1R , preamplifier.
Connect DB8e UHF antenna to the UHF connection of the preamplifier.
Connect the Y10-7-13 antenna to the VHF connection of the preamplifier.
No antenna rotator for the , DB8e and Y10-7-13 antennas.
Recommend do not setup a antenna or antennas with a antenna rotator at this time.
Here are some Above the Peak of the Roof Antenna Mounts.
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com
Here are some place to buy antennas and etc. .
www.ronard.com
www.amazon.com
