Old 20-Jan-2014, 12:47 AM   #9
bobdole888
Did you try the DB8 or DB8e?
Indoor mounting, including attic mounting is very unlikely to yield satisfactory results based on your report.
Have you tested reception outside, in the clear? If so, what antenna and accessories were used and what were the results?
Mileage estimates are not as accurate a tool as the gain specification. Mileage estimates are usually good faith estimates based on some unspecified assumptions... Gain values provided by the reputable antenna manufactures are based on repeatable measuring methods. You need as much passive antenna gain as you can get... Less gain is the wrong direction to be headed in.
I tried DB8, not DB8e.
Last time was a half hearted attempt so it was only indoors. I didn't try anything outdoors.
The only tool I have is my Tivo receiver, which has a signal strength meter.
I'll be sure to pay attention to the gain number instead of mileage rating for future antenna selection.
bobdole888 is offline   Reply With Quote
