OK, So the antenna is up at about 25 ft. with the preamp installed and a 50ft run of rg-6 quad direct to the TV. It is pointing generically towards NYC, not by compass.
Not much improvement over the indoor antenna i have hooked up on my 2nd floor TV.
Channels 2.1, 2.2, 5.1, 5.2, 9.1, 47.1,47.2 come in perfectly with the outdoor antenna.
No reception on channels 4, 11, 13 or any others.
On the indoor antenna i get the same as above, with much less reliability on all of them except 2.1 & 2.2. They come in pretty good on the indoor unless bad weather is rolling through.
Any suggestions? I can't elevate any higher as it is on a 5ft mast attached to a 4 inch vent pipe.
