Old 19-Jan-2014, 2:55 AM   #4
Install the DB8e in the attic.
Aim one panel at about 298 degree magnetic compass direction the other panel at about 238 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
As always , the starting antenna aim direction is the -->starting antenna aim direction.
Most Digital Tv's have a , Signal Strength Meter , and some Digital Tv's also have a Signal Quality Meter.
Install the , CM3412 distribution amplifier.
Connect a 4 way splitter to each output of the CM3412 distribution amplifier.
If reception situation/problems happen with the DB8e antenna in the attic that are not resolvable by adjusting the DB8e panels aim directions and changing/moving the location of the DB8e in the attic.
Move the DB8e antenna to above the peak of the roof.
Last edited by teleview; 19-Jan-2014 at 2:37 PM. Reason: Clarify information and typos.
