Old 19-Jan-2014, 2:04 AM   #15
Given that your TV Fool report is flagged: "WARNING: Address was only resolved to street level and might not be that close to your actual location. For more accurate results, try entering a specific address or coordinates.", it's uncertain if the data actually reflects the conditions at your location. In some locations, that can produce extreme errors in the predictions.
When generating a TV Fool report, my preferred method is to open the Interactive TV Maps tool. Leave the 'input method' set to the default, 'address'. Then, enter only the Postal Code, and then click the 'Map This' button.
At this point you should have a map displayed, with a movable cursor located at the center of the Postal Code that was entered. Use your mouse to drag the cursor to the exact location you're interested in. In the upper right corner of the map you can select view types, I find it helpful to use both.
At the bottom of the map, enter the antenna height. Please use the highest value that you can safely consider installing. If you aren't sure, then use 25'. FWIW, You can also find the LAT/LON coordinates of the cursor (in decimal form, not deg/min/sec).
Once the cursor location and the antenna height are set correctly, click on the 'Make Radar Plot' button located at the upper right corner of the map. The TV Fool report opens in a new tab or window. You can then copy the URL from the address bar of your browser, for posting to a thread.
I hope this helps, I just want to be sure we give you advise based on the actual conditions at your location.
As an aside, I have a DB4e and am quite satisfied that it's the best available 4-bay panel design currently available to the consumer market. The CS4 would not be a big step down in performance, but it would not be a step up either. I also contend with trees, my best advice is, 'avoid them if possible'. If you can't get over or around them, then try getting under them.
Please, be open to the sound advise ADTech has offered you thus far.
