Old 18-Jan-2014, 11:35 PM   #6
kach22i
kach22i's Avatar
The bottom line is, you won't know if you don't try.
I'll feel better knowing it at least clears the roof, and is high as it can be without introducing noticeable sway.
The original 1-1/4" (approx. dia.) 2-piece 15-foot light gauge pole did have some sway with the original larger antenna, plus it would sing when it got windy. In addition a woodpecker took a fancy to it for a few years, I still remember the banging.
Most likely in the spring I'll put up a 10-foot pole, 1-1/2" diameter 16-18 gauge and just live with the results.
I'm already getting used to some distant channels not coming in when it snows, takes a while to reset my mindset.
kach22i is offline   Reply With Quote
