Old 18-Jan-2014, 6:46 PM   #10
The sellers of the tiny little Tv antennas such as , and not limited to , what you have are making a lot of money with claims of magic Tv reception from as far away as Mars.
Your reception location has , 1 and 2 Edge Path obstructions , this means land obstructions , hills - mountains in the path of reception that are high enough to obstruct prevent the direct LOS=Line Of Sight transmission from the transmitter from reaching your reception antenna.
This is why I recommend the larger CM4228HD antenna to receive more signal for reliable reception.
The size is.
5 inch , front of the antenna to back of the antenna.
49 inch , wide.
33 inch , tall.
The broad flat reception surface does a excelent job of receiving Tv transmissions.
www.channelmasterstore.com
www.amazon.com
Use New RG-6 Coax , Outside.
To help keep weather water out of outside connections.
Use New RG-6 Coax that has the Compression type connectors on the ends of the coax , not the older crimp type connectors on the ends of the coax.
Disconnect and Remove -->ALL Parts<--of the tiny little antenna , Disconnect and Remove the antenna , Disconnect and Remove the power injector , Disconnect and Remove the power supply , Disconnect and Remove the coax.
Last edited by teleview; 19-Jan-2014 at 3:00 PM. Reason: Clarify information and typos.
