Old 18-Jan-2014, 2:49 PM   #7
RedAliCat
Yes, it is an excellent fit for your circumstances.
Be patient in selecting a mounting location for the antenna. Use a temporary mounting facility to test reception BEFORE drilling any holes. It is often necessary to relocate antennas due to channel-specific dead spots and it sometimes takes several test locations to find a suitable mounting location where everything 'plays nice'. You are in the shadow of the foothills and will be relying on diffracted signals. Don't be too surprised if you have to move the antenna a few times. Using the CJ mount's adjustable feature, tilt the antenna back so that the antenna is aimed up at the horizon to your north east.
Another advantage of the C2V is you can pick one up at almost any Walmart or Best Buy. Comes with a 20" compact mount in those stores.
Thank you for the advice about testing locations and tilting the antenna. Hadn't thought about either.
RedAliCat is offline   Reply With Quote
