Old 18-Jan-2014, 4:58 AM   #3
A Simple reception situation.
Above the Peak of the Roof ( not down the roof ).
Install a , www.channelmasterstore.com , CM4228HD , UHF/VHF antenna aimed at about 36 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Here are some Above The Peak Of The Roof Antenna Mounts.
www.ronard.com/909911.html
www.ronard.com/34424560.html
Use the , ronard (4560) , eave antenna mount.
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com .
A antenna system amplifier is not required.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Tv Reception.
The Best Practices is to install the Tv antenna at a location that has the least amount to no amount of obstructions in the directions of reception.
Digital Broadcast Tv Tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
Do Double Rescan to clear tuner.
www.wchstv.com/DoubleReScanAlert.pdf
