Old 18-Jan-2014, 3:12 AM   #1
RedAliCat
Question Reception Loss at Temperature 32 Degrees or Below, and PBS Channels Never Received
Yet another "cut the DirecTv bill" person here in Boise, Idaho, needing advice on why I'm losing reception on some channels when the temperature outside dips below freezing. Also, the PBS channels just don't come in at all, regardless of the weather.
Here's my stats:
TV Fool Antenna: http://www.tvfool.com/?option=com_wr...5b94def797dc41
Philips TV antenna SDV2940 UHF/HDTV digital Indoor/outdoor
, using it outside on our single-level house per this photo:
Antenna Setup by redalicat, on Flickr
Antenna came with something it calls a "Power Injector", so that's installed per instructions. Documentation says it's omnidirectional, but it's mounted at 56 degrees.
Wiring: Coax that had been attached to satellite dish, installed 1.5 years ago. Removed any splitters, etc.
This is just for one TV. When the temperature is above freezing, we do not receive the PBS stations at all but the rest of the main network channels come in fine. When the temperature hits 32F or below, both NBC and CBS pixelate and drop out so bad that they're completely unwatchable, sometimes the ABC channel but not as often. Since we watch TV mostly at night, this has become frustrating.
Don't know if this would make a difference, but I'm using a converter box, Apex DT504, on a 2002 Panasonic CT-32HX41E.
What I'd like: weather not to affect viewing of any network channel, and to receive the 4 PBS channels anytime. I'm pretty much interested in the main network channels, don't care if I lose the other oddball channels, some of which I seem to receive beautifully. I've considered mounting the antenna up on the satellite pole (with the dish removed) or even higher up on the house if it will help, but I don't know if that will work for me at all.
Bottom line: is this antenna worth working with, or should I pony up for something more/better? I'm only 10 mi away from most of the signals, and the manufacturer says it's 20 mi range.
RedAliCat is offline   Reply With Quote
