The line of sight signals are more likely to do OK with an omni style antenna. The weaker edge path signals are more doubtful. I'd start by verifying what channel CIII is operating on. If you need support for real CH-6, get an all-channel antenna such as the Channel Master CM3016 or larger (Consider similar product from Antennacraft and Winegard as well).
If no need for real CH-6 exists, then use an Antennacraft HBU-33 or larger (again there are similar products from other manufacturers).
If you are mounting in the attic, use a larger antenna if it can fit.
With one antenna, you can survey the reception landscape and make informed choices as how to proceed.
