Thread: 3 Cable Lines
Old 17-Jan-2014, 8:38 PM   #2
Your theory sounds very plausible, 'one coax to each outlet' would be a 'home run' arrangement, the preferred cabling scheme. You should be able to disconnect one cable from the splitter and confirm what it feeds then check the next.
Be sure to keep any cable company signals totally separate from your OTA TV system, you don't want to cause interference to licensed radio services by transmitting cable company signals through your antenna.
