Old 17-Jan-2014, 1:25 AM   #8
You may want to inquire with tinlee.com re. filters. One way to approach this type of situation is to obtain a filter for each channel that you want to receive. The signal from the antenna with the best quality copy of a given signal would be the source for a filter input. The output of all the filters would then need to be recombined into a single coax. Obviously, when there are many signals available, many filters may be required. Tinlee may be able to suggest other approaches.
An alternative to consider: http://forum.tvfool.com/showthread.php?t=2882
